Hello
I've been very interested in getting my feet wet in the DLG part of this hobby. Earlier this year I was inspired to make my own dlg with cheap parts and building methods. So I drew up a rough plan and created airfoil templates for the main wing.
The result is a 1.2 meter dlg with a hot wire cutted foam wing glued to a carbon boom. The tail fins are made out of depron and tape. Clear packing tape is the only reinforcement to the main wing. Despite it's simplicity it flies great! The launch is straight and it tracks really well. Thanks to the AG35 airfoil it floats well in dead air and thermals great from small bubbles. The rising air from a black sheet metal roof heated by the sun is enough to make this plane ascend into the sky.
The current setup is elevator/ailerons with servos glued to the boom in the nose.
Excuse the poor quality video!
I hope that some of you will try building a DLG because flying one is really addictive!
few questions:
What diameter CF rod are you using?
What thickness of depron for the main wing?
Can you publish your cutting templates (possibly demo video cutting)?
What electronics did you use (rx, battery, servos)?
What's your AUW?
(Sorry about the flood of questions, This has me intriuged!)
-I would recommend a 8mm CF rod.
-The main wing is not in depron, it's white foam (low density, quite weak. totally dependant on packing tape cover).
-I could try to find the templates I used and post them somewhere.
-Electronics: 2x 9g servo. HK 6ch 2.4ghz rx. The batteries are some kind of camera battery. I can measure their weight and size.
-The AUW is around 200g.
Could you be more specific about the main wing foam you used? What is it usually used for?
Also did you run your tape across or down the length of the wing?
I'm assuming it's 8mm CF tube, right? If so, how thick is the wall (or the inner diameter)?
Yes, Im sorry I meant CF tube. A rod would be too heavy :). I cant remember the thickness of the wall but a maximum of 1mm should be enough. I've tried with a thinner CF tube (~5mm or so) and it cracked after some power throws.
I've had my Mimi built around 6 mm hollow tube from Hobbyking. It gave up after full year of flying, including some nasty very rough landings.
As far as I noticed, CF tube holds on launching g forces pretty well. But hits on hard landings introduce cracks at stress concentration points (near the wing fix, in my case) and there it breaks on a next launch. I may be wrong, though, just my opinion.
i am interested in more info
keep it up
do you think you could build one with a kf airfoil out of foamboard also i am using a guitar string for my hotwire at the moment so it would be cool if you made a video of your hotwire.
thanks for the cool design
Paul age 12
Advise wanted
Paul age 12
Thanks
Thanks
Paul
Thanks Winkdogg
Thanks , Winkdogg
I have some questions regarding the wings and the airfoil.
I've found the airfoil here:
http://airfoiltools.com/airfoil/details?airfoil=ag35-il
So it seems to be flat on the bottom. In the photo where you parked your plane so nicely in the tree the airfoil looks different or attached at a different angle. Could you please clarify this.
From your description above I understand that you bend the wings a bit with the tape you apply. But it looks like there's also an angle in the center. Didi you make the wing of two pieces and assembled them with a slight angle?
Thanks for your inspiration and the plans
René
are the wings separate or one. if its one how did you put the dihedral in it using the tape. also where did you run the rod through?
thanks
