"Budget Build" AP Quad
by JUSS10 | June 18, 2015 | (6) Posted in Projects
The first quad I built was the Anycopter and once I got it in the air I couldn’t wait to get a camera on it. I went ahead and built a new quad with my own design but it still used the fixed camera that was slung from the bottom. Essentially the same as the Anycopter but with a bit more eye appeal. Recently I’ve really wanted to get a gimbal to attach to my quad. I don’t have tons of money to spend on this so I thought I would give one of the cheap $50 Chinese gimbals a try. I bit the bullet and finally ordered the 2 axis gopro gimbal from goodluckbuy.com. Deciding it would be easier to just build a new quad around the gimbal, I designed what I am calling a “budget” AP quad. As seen, this quad (minus radio and camera) comes in at right around $150 for all materials and electronics.
While waiting for the gimbal to arrive, I started working on designing a new quad. There were a few things I wanted to incorporate in to my design. After seeing the quad Eric built for the Naze32 episode, I wanted to integrate the 10 degrees “dihedral” to the arms. I also needed longer legs that gave stability but cleared the view of the camera. I looked at a few AP quads that are already out on the market and really liked a few that 3DR was doing so I took some styling cues from that and came up with the design below.
After I was happy with the CAD in 3D I exported it to 2D in draftsight and proceeded to collect the needed materials.
The material total for the frame is quite cheap. I just used 1/8” hobby plywood from Hobby Lobby. The booms are just ½ x ½ poplar dowels from the hardware store. I used all stainless 3mm hardware.
Here is a photo of the frame being cut out on the laser
Here are all the parts laid out before assembly. Quite a few pieces.
I did a quick build to make sure fit and finish was what I was looking for. It really started to look cool when I got the test build up done.
Once I was happy I tore it down and painted all the parts. I went with a matte black finish.
My last quad was a donner for many of the parts. I did get some new ESCs but I took the motors (turnigy 1400kv), flight controller (KK2) and receiver (lemon RX) from my old quad. Here is a side by side showing them in the process of moving parts over.
Here is a photo while half way along in the build process. I knew it was going to start to get “busy” once I started wiring it all up.
I took the top deck off and wired up the ESCs to the power distribution board. I just use a piece of copper clad circuit board for this. There are a few more “pads” there for installing a diode and switch for future LEDs.
And here it is after it was assembled and ready to fly!
I haven’t had much time to try it yet but the little bit of time I had it in the air it felt quite stable and has a great presence in the air. I look forward to getting some more time behind the sticks on this one and also giving the cheap gimbal a good workout.
Thanks for checking it out!
Justin
AP Quad CAD
Finally got some video from the gimbal. Works decent, definately needs some tweaking.
Material List:
- one sheet of 1/8" hobby plywood 1x2ft
- 8 1/2" x 5" long poplar dowels (can cut these out of 2 36" dowels)
- 24 M3x30 stainless bolts
- 24 M3 stainless lock nuts
- 4 1/2" long aluminum standoffs
- 8 3/4" long aluminum standoffs
- 24 4-40x.25 bolts (for standoffs)
All hardware was purchased from McMaster
Electronics:
- 4 turnigy 1400KV motors
- KK2 board
- 4 20A Simon K ESCs (these are an ebay specially, upon opening they are actually 30A and of great quality)
- 1045 GF props
- 2 axis gimbal from Goodluckbuy.com
piisceiss on June 21, 2015
If only I had a laser cutter
CJGFX on June 22, 2015
Nicely done.... Hope you can put a video of it in action on soon.
Will you be sharing the plans for this?
JUSS10 on June 22, 2015
Sure thing! I'll try and get the cad up in the next few days.
CJGFX on June 23, 2015
Cheers for the file.... It does look great and I'll be very interested to hear how you get on with the flights etc.... Keep us up to date
Grearson on June 22, 2015
awesome design =) Mind sharing it? and maybe some flight footage
monti.mauro on June 25, 2015
Amazing!... It would be great also if you can put the material list.
Thanks!
Jefftherckid on June 25, 2015
I think this kind of looks like the 3DR quad and x8 witch makes me want to build one out of g10 and aluminum. In fact I would like to build an x8 so this could be a possibility. Thanks JUSS10.
JUSS10 on July 13, 2015
Yeah I really liked the look of the X8 so thats kind of what I based it on. I added a few things here and there to work better with my equipment.
Andy Perry on July 23, 2015
Wow! great build, must have read my mind, exactly what i was looking at. any chance of sharing the solidworks drawings. I'd like to make my own modifications before creating a cutting list.
Thanks
JUSS10 on July 27, 2015
Sorry for the later response, do you want all the part files zipped or just a step file?
Malik98 on August 9, 2015
Great Design. I got one cut on a waterjet and have been flying it autonomous with an APM 2.6 for Aerial Photography for the past two months. Best quad I've ever had.
JUSS10 on February 20, 2016
Thats awesome to hear! Would love to see some pictures of it. Care to message me with some?
