If you have ever tried to mount any kind of camera to a plane or multi-rotor, you will know just how hard it is to get sharp, ‘jello free’ video.
Isolating the camera from the vibration caused by motors and propellers can be more difficult than designing, building and test flying the machine! The challenge is to mount the camera firmly so that it doesn't move around, but at the same time isolate it from vibration. I have spent many hours designing and testing and have finally come up with a solution that works.
This design has been successfully implemented on my Tricopter and Quadcopter so far. Here are the details of the mounts and materials used:
Both mounts use the following materials:
- 3mm plywood
- 1.5mm fibreglass sheet
- 6mm silicone fuel tubing
- M3 thread 25mm long
- 30 minute slow cure epoxy
- Strong self-adhesive velcro
- Foam rubber material
Tricopter
Tricopter camera mount shown assembled. The camera effectively hangs from the velcro. The fuel tubing applies a small amount of pressure which keeps the velcro in contact and stabilises the joint. The silicon tubing tension can be adjusted depending on the weight of the camera.
Camera mount removed from the Tricopter. The plate is a laminate of 3mm plywood and 1.5mm fibreglass sheet epoxied together. This forms a dense and rigid plate that soaks up vibration well and provides a firm platform for the camera.
There is foam material sandwiched between the velcro. It is 6mm thick and has the consistency of soft neoprene. Neoprene would probably be a good substitute for the foam I used.
Tricopter camera mount underside showing the excellent and very strong self-adhesive velcro sourced from Hobbyking.
The fuel tubing is secured in place with a short length of 3mm threaded rod. I cut the head off an M3 bolt.
Quadcopter
The quadcopter mount is very similar, but it also carries the weight of the 5000mah 4S flight battery. The total weight of the mount with camera and battery is 750g. Larger velcro contact areas and two fuel tube bands are used to support the extra weight. The additional mass of the battery also makes the mount more stable and absorbs some of the vibration.
*Since writing this article I have moved the battery from the camera mount and the results are just as good without the mass of the battery on the mount).
The quadcopter also has a separate support plate attached to the main frame by 2.5mm bolts suspended on rubber grommets. I don’t know if this extra stage of suppression is required, but it certainly can’t do any harm.
Quadcopter underside.
Quadcopter camera mount components.
Camera mount shown fully assembled.
I hope this article saves you from hours of frustrating testing, let me know how it works for you?
