Solder school: XT60
by wongthomas | July 3, 2012 | (18) Posted in Tips
This is just a quick howto on soldering XT60 connectors, used on a lot of batteries from HobbyKing.
Just make sure that you use the right size shrink tube
Hope you enjoy
Grumpyreview
Gryf on November 15, 2014
Thanks for the tutorial! I might add, having soldered on a few XT60s myself, that I found it helpful to plug in the other half of the connector while soldering the first one... that way, if the plastic softens, the pins/sockets will still be properly aligned.
Thanks!
Solder school: XT60
