This article explains the benefits of parallel charging lithium polymer (lipo) batteries.
It does not cover lipo battery basics. It is recommended that you look at this article and become familiar with lipo selection and charging before attempting parallel charging.
When charging batteries SAFETY is critical. The usual precautions apply:
Do not charge batteries unattended.Charge in a safe place (fireproof bag or box is recommended away from flammable materials).
Parallel charging is safe; however, the following additional precautions apply:
NEVER connect batteries of different voltages together in parallel. Make sure that all the batteries are the same cell count and voltage.
Be aware that once batteries are connected together in parallel, if something does go wrong there is more energy stored in the batteries which in the worst case could damage multiple battery packs and damage property through fire.
i have a skyrc e6650 and would love to be able to parallel charge my batteries but am abit worried about killing my charger/batteries :P
on final question.. i think..
is..
how do i work out what is a safe ampage to charge my batteries at..
i kno that no more than 1c is the recommened for most batteries but how do i work this out.. as if i am charging my 5 2200 3s i want to be charging at more than 1amp.. :/
but if it saves me a few hours and the hassle of having to watch it all.. its a bonus for me :)
thanks alot for ur help..
so for my 1300 does this mean i can charge it at 1.3*5=6.5amps.. or am i way off the mark here.?
Just curious how you end up with all of your batteries so close to the same voltage. My voltages end up all over the place. I usually end up only being able to charge up two or three together at one time due to the voltage differences.
Thanks !
