Make a Cheap C.G. Stand
by HoriAkuma | September 8, 2012 | (20) Posted in Projects
You will need:
  • (1) 3/4" x 8' piece of PVC pipe, cut into the following pieces;
  1. 12" x 2
  2. 8" x 2
  3. 6" x6
  • (6) 3/4" PVC L-joints
  • (2) 3/4" PVC T-joints
  • (2) 4 1/2" x 1/4" rounded top steel bolts
  • (4) nuts
  • (4) washers
Use both 12" sections, four 6" sections, two T-joints, and four L-joints to make the base, as shown below.
Drill holes through both ends of each 8" piece, just big enough for the bolts to fit thru.
Insert the bolts and use a ruler to make sure they are even, before tightening them down, as shown below.
Use the remaining 6" sections, and the last two L-joints to make the arms.
Attach the arms to the base, and you're all set!
The arms can also be swung in or out, to fit several differently sized and shaped planes.
adidarc on September 12, 2012
Very good idea! PVC is great stuff.
DejaD on September 10, 2012
I have used this same technique for my plane transport racks and work stands. I never thought to use it for a CG stand, good work.
HoriAkuma on September 12, 2012
Thanks, guys!
gvt4089 on September 14, 2012
i made mine with a prop for my airplane on it too.. great idea
808aerosquadron on October 29, 2012
Great, inexpensive CG stand. Works very well.
Just be sure and sand the pipe ends and joints BEFORE you do your test fit - those things are snug even with just a test fit!
WarbirdFan66 on September 20, 2012
very good idea man, nice work
jd7792 on September 10, 2012
Great idea, just shows you that sometimes simplest is best! Use no glue and it would be altermitaely portable!
htomnlinda on September 13, 2012
I'm going down to Lowes to get the PVC today. What a great idea !!!
Thanks
