Callum. W
All RC planes have a centre
of gravity (CG) this is the also known as the balance point. If the plane
balances in front of the CG point it is said to be nose heavy, aft of the CG
point and it is tail heavy. There is an old saying "a nose heavy plane
flies poorly, a tail heavy plane flies once." A tail heavy plane has
hyper-sensitive rudder and elevator movements making the plane very hard to
control
Instructions
Use the
ruler to mark the wing where the suggested CG is located. Mark the underside of
the wing on a high wing plane and the top of the wing on a low wing plane. The
marks should be as close to the fuselage as possible.
Place
your fingers on the spots you just marked. Your fingers should be under the
wing on a high wing plane. Low wing planes are balanced up-side down so that
the bulk of their weight will be below the wing.
Balance
planes that have fuel tanks aft of the centre of gravity full of fuel. The
plane will become gradually nose heavy as the fuel is burned.
Lift the
plane and pay close attention to the nose, if it drops then the plane is nose
heavy, if it raises then it is tail heavy. A slightly nose heavy plane will be
more stable in the air and easier to fly.
Move
equipment like receivers or battery packs forward or aft to try and balance the
plane; add weight only as a last resort.
Tips & Warnings
Buy stick on lead weights, they
can be cut into ΒΌ ounce sections and have peel and stick adhesive on the back.
Never fly an unbalanced plane,
have an experienced RC pilot help you if you can't balance the plane yourself.
