To use a servo reverser or not. While the convenience of a servo reverser is quite appealing but there are some instances where space, weight or logistics don't allow from the easy of a reversing module. The attached video will step you through reversing one internally. I have shown this on a 9G servo but the principle applies to all sizes. Don't let the intimidation of opening up electronics detour you, it's quite a simple process. The basis is reversing the positive and signal line as well as the positive and neutral on the servo motor. Good Luck and hope this helps.
Scott
Thenk you!
JB
Also helps those whom want to add flaps to there model.
For example for the Multiplex Fun Cub Flaps ;-)
