Hot Wire CNC foam cutter
by rckeith | July 25, 2012 | (24) Posted in Projects
This article shows how I built a hot wire CNC (Computer Numerical Control) foam cutter.
and this is the Hawker Hurricane finally finished
Why would you want to build a hot wire CNC foam cutter machine?  For me it was a way to build wings and fuselages for RC airplanes that weren't readily available.
Traditional building methods for RC airplanes involves lots of Balsa wood cutting and gluing many parts together.  I can cut a foam wing core in about 15 minutes and usually I cut several at time.  Building your own models is very rewarding and when they fly well its a real buzz.
After a lot of research and some real good advice from CNC forums ( http://www.mycncuk.com/ and http://www.cnczone.com/
Here's my plans and full detailed build page on my website http://www.rckeith.co.uk/cnc-detailed-build-plans/
All the wood material came from an office clearout, old desks
The electronics can seem quite daunting but if you can build a electric airplanes and wire up motors and speed controllers then you should be OK
I purchased the electronics from Ebay and built my own power supply.  But I noticed several ads now including the power supply.  Just do a search on Ebay for "4-axis CNC"
For the power supply I used two old computer PSU from the same make and model of PC. Nice atricle here on how to do ithttp://www.procooling.com/index.php?func=articles&disp=52&pg=1
The lead screws are threaded rods mine being M8 thread.  Because foam cutting doesn't have to be as accurate as other materials e.g. wood and aluminium these are OK.  You can get proper Lead screws but these tend to be expensive. If I were to build a cnc router I would probably use lead screws as they eliminate any backlash.
The towers run on drawer slides which you can get from most DIY stores.
The X-axis use a captive nut the one with spikes on that bites into the wood.  The Y -uses a small aluminium block which I drilled and tapped the threads into.  I’ve tuned the ends of the threaded  to match the size of the stepper motor spindles and used rubber hose with two hose clips.  Seems surprising solid and gives a little bit of flex
I've used a old Dell computer running XP and no other unessecary software installed.  You need a PC with a parallel printer port usually known as LPT1
To control the cnc machine you need some software and after much research I decided to go with Mach3 from ArtSoft http://www.machsupport.com/ its very well supported and there are several videos on YouTube that describe how to install and configure.  There is a free version that allows 500 lines of g-code to run.
G-codes are the instruction for the machine that tells it how far and what direction to move he stepper motors.  You don't need to learn g-code as there is software to convert drawings into the code.  I've tried a couple Foamworks and Profili2 and have settled on Profili2 which does a lot more than generate g-code for wing profiles.
The wire between the 2 towers is tension by a spring so they can move interdependently for tapered wings.  The wire is usually ni-chrome but several other can be used including guitar strings.  I've powered my wire with the iCharger 208 which has a foam cut program but I have used a car battery charger connected to a house dimmer switch for manual cutting.  This allows control of the heat and works very well.
Its quite exciting when you get it all powered up and move the cursors keys and see motors spinning.  The video show a small test airfoil which was about the 5th attempt.  The hot wire cuts my radiance so its basically melting the foam in front of it.  My first pieces were not very good as the feed was too slow but as you can see it didn't come out too bad when I cut the feed right
My next cut will be a flying wing just to see if I can do it.  Profili2 Pro http://www.profili2.com/ is very good for generating the code and has a massive database of airfoils.
Update
Here are some of my first tests.
Hope you found this of interest and if you need any advice or help leave me a comment or check my website out www.rckeith.co.uk
The only difference between men and boys is the price of their toys!!
Keith
LTCjRet on August 18, 2012
Keith, did you have any problem receiving/downloading the plans after you paid for them? I submitted my PayPal payment, which was readily accepted, but didn't get a link for download. I've sent several emails and even left a phone message but haven't received a response.
Shaun_Mileson on July 26, 2012
Wow!I didn't think it was possible to build your own cnc...one day I'll give it a try. Thanks for the insight.
earthsciteach on July 26, 2012
Very nice. What was the total cost?
rckeith on July 26, 2012
The controller board and stepper motors were about £140 the slides were about £30 and most of the other parts I was able to get for no cost. I work in the computer industry and was able to get PC power supplies from end of life PC's and even a complete PC to power the system . Mach3 software is free up to 500 lines of code (not found that an issues yet). I did purchase profili2 which was £47. So it total about £220 or $350 US
Keith
House Of Noob on July 28, 2012
That sounds SO MAD SCIENTIST!!!!!!
Fantastic article! Thanks for the info.
beastdude97 on July 15, 2013
DUDE, that is truly AMAZING, if only i knew how to do technical stuff like that
rckeith on July 15, 2013
Its not that difficult, just take a bit of time to research it out. Lots of good help on the net. Anyone to can build a RC plane can do this.
Keith
im surprised you were able to do all that for only $350.....definitely 5 stars
A lot of this was old desks from a office clear out and old PC's that were being scrapped (PSU) Since building this I've spent more on software to make it work such as Mach3, Profili2 and DevFus. I'm going to build a CNC router next which I'm designing in Sketchup and this will use the same software and driver board as the foam cutter. I'll post another video when its done.
Keith
Salvador lz on August 6, 2013
Very nice, I´m designing a very similar cnc and I have one question, what motors did you use?, because I want to buy a kit with nema 23 278 oz-in stepper motors, but I don´t know if thats enought torque for this cnc
rckeith on August 6, 2013
Hi
I used NEMA 23 this is the part number 57bygh56-401a . I got them with the TB6560 controller board from ebay. So far I haven't had any problems
Keith
Salvador lz on August 7, 2013
Thank you very much
bluegid on August 14, 2014
What I find maddening is that that someone can build this impressive machine, something I would love to be able to do but nevertheless accept as being far beyond me (a mathematical physics graduate), and yet in the text which appears in the video the most basic yet egregious, grammatical error that most 7 year olds would spot is left uncorrected. I find this maddening because to correct it would take only a few moments but make so much difference; to avoid it in the first place would have taken not even a moment's thought, nothing compared to the hours of effort and application of intelligence and deep understanding that must have gone into the realization of this project, and therefore I just can't resolve this in my mind and it leaves me perplexed and angry because I can't begin to understand how it can be. It leaves me frustrated that there must be something that I'm missing which would make sense of this and correct my world view but I honestly can't think what. Please enlighten me someone.
joe_crash on October 18, 2018
If you ever worked in the world of professional programming you'd know that any written documentation is the most dreaded and delayed portion of a product - generally put off until the last second and usually rife with grammatical and spelling errors. In fact most places hire a technical writer to do it because if it's done by one of the programers it's not going to be done well. I imagine it's something along those lines added into the fact that online communication is a mish mash of written and verbal communication, and people take short cuts so the written communication is at verbal communication speed and most people can't type that fast.
bluetear000 on April 24, 2015
RCkeith where did u get the link to the PDF plan as i have not gotten any thing or response from the guy selling the plans???
Thanks in advance
rckeith on April 25, 2015
I've had a few guys contact me with the same issue. The plans are copyrighted so if I send you a copy I'm breaking the law and could incur a fine of up to $150,000. I going to do my own because I made some modifications which I'll post asap. In the meantime there are a lot more details on my website including setting up the electronics. http://www.rckeith.co.uk Send me your details via my website contact form and I'll send you a copy as soon as there done.
zann68 on May 11, 2015
Hey did you use NEMA17 or 23. Will NEMA17 76oz work?
Well let me adjust my question now that I see you used NEMA23's will NEMA17 76oz work?
rckeith on May 14, 2015
Sorry for the late reply been away for a few days.
I don't think Nema17 will be powerful enough. It's quite a big machine and fairly heavy. If you were to build in lighter material such as aluminium then they would probably be OK. Having said that I have no experience of the Nema17 and if you build was light and very accurate so everything moved very easily they could be OK.
Hope that helps
Keith
Any product that includes 5 days of training by dedicated trainers who come to your location immediately tells me that the price is so over my project budget I may as well go immediately to a different site as it would be a waste of time!
