AIRFOIL: http://fpv.no/vbulletin/attachment.php?attachmentid=4091&d=1336508016
Root chord : 37 cm
Tip chord: 24 cm (inncl aileron - 18,5 without)
Wingspan: 172 cm
Blunt section : 28 cm wide
Sweep: 30 degrees
CG Calculation: http://fwcg.3dzone.dk/?wing_span=172&root_chord=45&tip_chord=24&sweep_type=1&sweep=30&cg_pos=25&show_mac_lines=0
Norwegian video of the making of the wing cores:
http://www.youtube.com/watch?v=gViNw4y95J8
You wont get the oral explanation, but it shows how to make the wings.
UPDATE: HERE IS RAW UNSTABILIZED FOOTAGE FROM THE GOPRO.
PS !!! It is also the safest way to launch - you dont want that propeller cutting your fingers.
This will probably be my next build!
However it flies extrodinary stable. I will update the article with raw GoPro footage - absolutly unstabilized from my channel.
CG is calculated INNCLUSIVE the ailerons.
