Here's an ultra cheap DIY pan and tilt setup made with spare parts, wood, tape and of course... hot glue! A simple design that is servo driven and allows you to have pan and tilt movement for your FPV camera on your RC flyer.
Here's the parts list:
2 X Pieces of wood 26mm x 5mm x 90mm
1 X Wood dowel ⅝” X ⅝” (16mm X 16mm)
1 X Hobby Plywood 1/16” (1.5mm)
1 X 1mm Piano Wire
1 X 2mm Piano Wire
1 X Steering Arm
2 X Linkage Stoppers
1 X Zip Tie (8”)
2 X Servos
Hot Glue
Extreme Packing Tape
Chad designed this pan and tilt setup for specifically for our Fat Shark Head Tracker Review and needed to create it fast and cheap.
Even the hinge setup is created with some hobby plywood and tape, because not everyone has extra airplane flap hinges available.. and the hobby plywood and tape is easier.
Digital servos are the best choice for this type of FPV setup because they offer better resolution. The resolution referes to the steps or 'stops' you get as the servo moves. The more steps (resolution) means smoother pan and tilting movement.
Again, this is just one way of designing an ultra cheap, super simple pan and tilt setup for your radio controlled FPV flyer. We encourage you to go out and try this build or design your own!
If you have a setup that you've designed share it in the forum, and if you've made this setup be sure to post it so we can check it out!
Click the "Join the Discussion" link below to go to the Forum!
https://www.youtube.com/watch?v=KPBL4pPEzNI
You´r using this red little tool to make the Z for the Servohorns.. can you tell me where i can get one of this.. because i realy need this tool =)
(Hobbyking?)
Greatings from Austria
there are various hobby stores that have them or ebay
http://www.ebay.com/itm/DU-BRO-E-Z-Bender-Wire-Forming-Tool-062-093-481-/200798049872?pt=US_Radio_Control_Control_Line&hash=item2ec07f1650
Why don't the links work?
Its just because of a few people/communities like you that these hobbies are becoming more affordable, more accessible, easy to follow up and inspirational.
Keep up the good work
Thank You Guyz(Each and every member of FT) :D
From a newbie/NowAnIntermediate (quadcopters)
