DIY Silicon vibration dampers 2.0
by jamiedco | November 19, 2012 | (0) Posted in Projects
Hello All
V1 dampeners were awesome but they had a few problems . like bouncing to pieces every time i landed a tad aggressively .
so v2.0 has some major changes . the first is replaced the nuts and bolts with m3 wing nuts. having changed the nuts and bolts the dia went up to 20mm. i was worried about them being to stiff but it seems to work well .
i made the mould at work on the cnc . I milled the holes out 15.4mm deep . it was ment to be 15mm but i was machining by hand and got carried away .
i cast them the same as before. i mixed silicon and corn starch . the mix i used is 33% cornstarch and 66% silicon . after 16 hours i spilt the mould and pulled them out .
one thing i found once i changed over to this the quad seams alot more diled in and precise . it also seams to track alot better than the pu foam i had in there . i will be posting the footage on my site later this week .
www.jamiedco.com
http://www.youtube.com/watch?v=ohWkZTPRydg&feature=plcp
No Comments Yet
Be the first to leave one!
