Coax Cable ?
by Doctor3 | August 14, 2012 | (10) Posted in Tips
This is a very short article about Coax cable . Which is written in the hope to help people soldering into/wring/ modifying coaxial cable
Coax cable ( coaxial cable in long ) is a wire used for high frequency electronics . such as Antenna's , FPV gear ( video wiring or transmission ).
The key feature is it is 3-4 layers . The inner core is the transmittion cable ( positive as it were ) , this is surrounded by an insulation material and then a wire shield        ( ground ) which acts as a barrier to stop the high frequencies being lost .
The reason for this is because when the signal is high frequency the electrons within the wire that carry the charge ( responsible for letting electricity " flow " ) are pushed to the outside of the wire . This is because they " bump into " each other in the centre so spread to the outside . The shield layer is necessary to stop the frequency / energy / charge as it were escaping.
In order to solder into this wire it is important that your positive signal is shielded to reduce losses . Secondly do not let the inner core touch the outer as this will disapate the signal ( short circuit) . Applications for Coax cable include Antenna wiring, Video cables such as FPV ( when looking at the field of aero modelling) .
It would be good to keep the inner core insulated and add foil around this to protect the wore from RFI interference.
Thanks Eddie / Dr.3
http://www.ehandfordap.moonfruit.com/
http://www.youtube.com/user/ehandford?feature=mhee
hans on August 16, 2012
Short but informative. I like it. I don't know enough about this to find mistakes (if any) :).
Doctor3 on August 17, 2012
Thanks for the feedback :)
subsonichobby on September 3, 2012
Here are a few steps to make inverted Vee antenna.
http://subsonichobby.blogspot.com/2012/09/diy-inverted-vee-antenna-for-fpv-900mhz.html
Doctor3 on September 4, 2012
Ah cool, thanks very much :)
Coax Cable ?
