Camera button switch
by Doctor3 | August 9, 2012 | (10) Posted in Projects
I really wanted to take high definition photo's and film using my multi rotor ( the H- copter ) so i decided to swap the FPV gear for a digital camera.
I mounted the camera easily ( and no it isnt anti vibration mounted but it seems OK for now , but if you have any ideas for mounts please post ), but set out to make a button press
My solution is very simple (argueably crude) .
The servo arm was dramatically shortened in order to provide a higher torque "push" . i could have used a larger servo but in order to access the power button a smaller (3.7g) servo was used.
The servo is plugged into the gear/ aux plug , which means no self levelling though (kk2 board used). By adjusting the Travel Adj settings it ensures the shortened servo arms presses the correct amount.
I used tie-wraps as it allows for super easy adjustment before final tightening.
The results were very pleasing :)
Kit used -
3.7gram servo
http://www.hobbyking.com/hobbyking/store/__5459__Hobby_King_3_7g_4kg_10sec_Micro_Servo.html
10cm servo extension wire
http://www.hobbyking.com/hobbyking/store/__9707__10CM_Servo_Lead_Futaba_32AWG_Ultra_Light_10pcs_set_.html
Samsung St 66
http://www.amazon.co.uk/gp/product/B007JT02S0/ref=s9_simh_gw_p23_d0_i2?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-2&pf_rd_r=1TW1882B4N6A1VPFTJSY&pf_rd_t=101&pf_rd_p=317828027&pf_rd_i=468294
Micro Sd card 8GB
http://www.amazon.co.uk/SanDisk-8GB-microSDHC-Memory-Card/dp/B002NTW99G/ref=sr_1_1?s=electronics&ie=UTF8&qid=1344536020&sr=1-1
Camera screw
http://www.amazon.co.uk/Kaavie-Adapter-Trigger-Microphone-Digital/dp/B004KIVTQ2/ref=pd_sim_ce_1
Total cost around £85 (camera being 70 - nought from Jessops )
or $130 .  (mount costing £7 or $11)
Thanks from Eddie - Doctor3
please rate :)
FoamingInMI on August 10, 2012
Simple but effective. I used the same technique years ago on my first AP plane which was a 3 channel. Had the shutter servo on the rudder stick & just flicked my thumb to take a (usually bad) pic.
Twisterr1000 on August 19, 2012
As you are doing the price in £ I guess you live in the U.K. ! anyway, do you know anywhere to get cheap fpv stuff or shall I just get it from hobbyking internatonial warehouse because I asked them if they were going to get any fpv stuff in the U.K. warehouse and they said no. :(
Doctor3 on August 19, 2012
yepp i live in the UK ! woo :)
Urm yepp seeing as i dont feel inclined to be hobbyking biased anymore i found the best places was ebay and amazon.
Stand -
http://www.amazon.co.uk/gp/product/B004LDURVE/ref=oh_details_o03_s00_i00
Camera -
http://www.amazon.co.uk/gp/product/B001GQ7QZY/ref=oh_details_o00_s00_i00
Screen -
http://www.amazon.co.uk/gp/product/B005Q6JNV0/ref=oh_details_o05_s00_i00
and various 3 cell lipos ( i would just go for cheap ones as no real current draw)
however the transmitter is up to you really. if you've got a 2.4ghz contoller then dont get a 2.4ghz fpv gear. ebay sells cheap and powerful stuff - depends on your price range. 900mhz , 1.2 ghz are way cheaper and more powerful longer range etc. but are "slightly " illegal
Jeriah on August 10, 2012
cool way to take pictures!
Doctor3 on August 11, 2012
Thanks ! :)
casehatter on August 13, 2012
Good job and great pics. Have fun and show us more man..
Doctor3 on August 16, 2012
thanks a lot ! :)
mena142 on September 19, 2012
Yup :P...quite a crude implementation, but it works without having to modify the camera or anything. It'd be cool if you could also post some of the picture you've taken!
