Calke Abbey - Spring Preview by ycopter
Rating: 4.60      15 ratings
Posted: June 7, 2012  |  840 views
INFLUENCE 76%
The National Trust has kindly given me permission to film within the extensive 600 acre grounds at Calke Abbey.  It really is a dream to fly through the ancient woodlands, formal gardens and around the historic house.
In return I am producing a promotional film for Calke.  This extract is taken from two adjacent flights and is 100% actual flight speed.  I have resisted the temptation to edit this too much, most of the footage is uncut which will hopefully give a good impression of the experience of flying through such a beautiful landscape.
Enjoy…
Comments
SuperCub92 June 8, 2012
u really do have an eye for wot looks good.. this looks brilliant and really doesnt need editing :)
keep the videos coming (Y)
ycopter June 8, 2012
Thanks, more videos coming when I can find time to edit the raw material!
ukbozzy June 11, 2012
Hi ive pm'ed you.
ycopter June 12, 2012
Please PM with your email address, I can't send a PM to you, it fails every time, no idea why!
House Of Noob June 8, 2012
Lovely flight
Thanks
sprout_less June 12, 2012
Did you do any color adjustment? This looks amazing!
I use PowerDirector 10 to edit and on this video used a setting called "Video Enhancement". It sharpens the image and adds a little more saturation, but to be honest I usually don't enhance the video at all, the raw footage from the GoPro HD2 look great without any enhancement.
Correction, I didn't use any enhancement on this video, I used the "Video Enhancement" on the previous video "Tricopter Testing - HK KK V1 board".
stephen June 15, 2012
That was brilliant I want one of them
Huwy11 June 8, 2012
Nice work =D
Were you using a GoPro for the FPV or did you use two cameras?
ycopter June 9, 2012
Thanks Huwy11.
I have used the GoPro live feed in the past and it works pretty well, but now I use a separate FPV camera and this is why:
1. The GoPro uses average exposure, so either they sky is clearly visible or the ground, but never both. I now use a camera with wide dynamic range (WDR) which exposes the sky and ground separately.
2. If using the GoPro case to protect the camera, you have to drill a hole in it for the video cable to pass through which makes the case non-waterproof!
3. The live output reduces the GoPro battery life quite a bit.
4. When the GoPro battery is exhausted the camera turns off and the FPV feed goes with it!
5. You don't have to have the GoPro onboard to fly FPV.
Log In to leave comments
