Basic information for Trainer design by seanfoster
Rating: 4.22      9 ratings
Posted: July 24, 2012  |  985 views
INFLUENCE 51%
     When thinking about designing a good trainer model, There a few things that you should take into consideration.
  • High Wing design.
          Having a high wing ( attached to the top of the fuselage) will help lower the center of gravity. Basically, this means the plane will "hang" from the wings. This will in turn make the make the plane less prone to roll. The bad         side of this how ever is, it will make inverted flight a little tricky.
  • Dihedral.
        Dihedral is the upward angle of a fixed-wing aircraft's wings where they meet at the fuselage. This helps create a self righting or leveling effect on the plane.       Meaning, after you have initiated a right or left bank using ailerons, the wings will           force the plane to level out of the roll once the ailerons are returned to the neutral           position.
  • High lift airfoil.
                 When considering the design of your airfoil, it is best to use an asymmetrical or semi-symmetrical airfoil. These designs have a great amount of lift, but at a cost of higher speed. This is god for more manageable speeds for beginning pilots.Even if you lose complete motor power, the plane should have a very decent glide slope to allow for a dead stick landing.
Below is a basic illustration showing the measurements and proportions of a standard trainer plane.
  I find it easier to start out with the dimensions  of your wing, and go from that point to design and build the rest of your plane. Once you have the wing span, the chord, and the airfoil design, You can then start to get the rest of your planes measurements from that. You can also calculate the wing load of your wing to know how much weight it will lift, and figure out your power plant as well.
Here are a couple of links that I have used to help with calculating wing load, and power sizing.
                   Wing loading
http://adamone.rchomepage.com/cg_calc.htm
                  power calculator
http://brantuas.com/ezcalc/dma1.asp
Hope this is useful to some newer pilots out there trying to get their feet wet in electric rc flight.
Comments
No Comments Yet
Be the first to leave one!
Log In to leave comments
