New Bird and New D.V.R.!
Something from a few weeks ago.
Plane used:Scratch-Built-Foxbat XV-1.
Gear Used: Flysky 6 ch TX
Twinboom pusher, 2200 kv (stock axn replacement motor). 30 amp esc Exceed-RC
.6*5.5 prop. GWS
Single-axis gyro Exceed-RC Drift Pro
SecurityCam-2000
600TVL SONY SUPER HAD CCD D-WDR Color Board Camera with OSD Menu DNR
EagleEyes F.P.V. station.
Video RX: Boscam RC305 5.8GHz with Hand Built Helical Antenna 7 turn
Video RX: Boscam RC305 5.8GHz with Hand Built C.P.Antenna
Video TX: Boscam 200mw 5.8 GHz with Cloverleaf Antenna
3 lobe cloverleaf on the bird.
FatSharks are the Bomb!
She was quite nice down low,till I ran her through a tree or two.
Good Job
You ought to git a lil Tx Rx cam combo and slap it on a bird you are friends with.Why then all you need is a little screen of some kind.If you feel like dropping the $$ on a pair of video goggles..well heck.You will be set for short range.(stock 5.8 gear got us bout 250m)If you build good antennas then you can go much further.Now you can sit in your car with the heater on.=)
