5.8ghz Reciever heatsink
by apache64 | January 4, 2014 | (0) Posted in Tips
If you fly 5.8Ghz FPV then your probably using one of the RC305 Recievers which are great recievers for the money. In using them however you may notice it gets rather warm after a few minutes use, and even more so in sunlight.
This is due to the PCB having a 78H05 linear regulator on it which disipates the difference between a 3S lipo down to 5volts. I use the Reciever fequently and in summer found it got warmer then i would like, but in winter this is not a problem.
This mod will allow the regulator to disipate the heat through the metal case and thus keep it cool, and make it more reliable.
You will just need a thin piece of copper cut to size 10mm wide x 25mm long, a pair of long nosed pliers to bend it into shape.
Once bent to a 'L' shape, you should tin the short side of the copper so it is ready to solder onto the PCB, and also tin the PCB aswell.
Once soldered the copper can be bent over like shown, thus allowing it to touch the case, and be removed without snagging on the case.
Once it is done put it all back together and feel the differnece in how the heat is more overall rather than in a hot spot, this should make it more reliable too. The Reciver module actulally uses 3.3Volt, so if you use a 2S lipo it would be even better, as the regulator would not need to disipate so much voltage difference.
dammuozz on January 5, 2014
i use it with 2s and it works just fine even in summer
Jsut210 on January 5, 2014
What I would do is pull up the regulator and solder in a little sBEC.
apache64 on January 6, 2014
Hi, that would be a better idea, but i am not sure if it would fit, and second if the noise from the SBEC would cause some sort of radio interference.
Hasi on January 6, 2014
The receiver module needs 5V. Check the datasheet!
I am sorry but what do you mean? the 5v regulator is there to produce 5V for the Rx module, but the whole RX is spec'd to have a 12V input.
petedotnl on January 4, 2014
good thinking! simple and safe
