3D Printed µQuadcopter
by FSMultirotors | September 13, 2013 | (5) Posted in Projects
As a 13-year-old, I've been playing around with multirotors for a while now, so I decided to make a µQuadcopter (Microcopter). My goal was to create a 3D printed 4 rotor platform using the KK2. I wanted to have 10+ minutes of flight time, altitude hold, and enough thrust to lift a gopro and some FPV gear. Now, its able to lift 1.75 pounds extra (with a Turnigy 2s 25c 2200mah lipo). The altitude hold is achieved through the HefnyCopter firmware and a sonar module.
All done! I'musing 1811 Turnigy 3800kv motors, 5030 props, and a Futaba 7c FASST radio system.
With a GoPro Hero 3
The 3D printed frame. It was printed on a Makerbot Rep2 on medium qualaty using red and black PLA. The STL files are at located here: https://www.dropbox.com/sh/18c1u8n6gb1jl22/tikfbdtuMs/%C2%B5Quadcopter%20STL%27s
 The STL's came off of thingiverse (Thanks beark54 and tosjuenfs).
Here are the 4 awesome brushless outrunners I used. At first, I made the mistake of ordering 1500kv motors from hobbyking, thinking they would have plenty of power. Due to my 3 plade props and the lack of power, it would only fly 6inches off of the ground. I found that I need a least the 2900kv motors, but for heavy FPV gear the 3800kv motors would be needed. Theese are all Turnigy 1811 motors from hobbyking. Each motor draws ~6amps. http://www.hobbyking.com/hobbyking/store/__8479__Turnigy_1811_Brushless_Indoor_Motor_3800kv.html
Here are the settings I fly with on my ESC's. I am using 6amp Turnigy plush ESC's so flashing them is very easy.
Here is the KK2, flashed with the HefnyCopter firmware. This firmware adds altitude hold, and many other useful features. http://oddcopter.com/2013/02/14/hefnycopter-brings-altitude-hold-to-the-kk2-0-flight-controller/
For a sonar module, this one iscompatible: http://www.amazon.com/SainSmart-Ultrasonic-Distance-Mega2560-Duemilanove/dp/B004U8TOE6/ref=sr_1_1?ie=UTF8&qid=1379083592&sr=8-1&keywords=HC-SR04
Here's a scrrenshot of the KK2 flash utility used to flash the new firmware on.
For the FPV gear:  HD Wing Camera http://www.hobbyking.com/hobbyking/store/__17200__HD_Wing_Camera_1280x720p_30fps_5MP_CMOS.html
300mw 1.2Ghz TX http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=11_30_38&products_id=1017
RX, with upgraded SAW filter http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=11_34_44&products_id=911
RX antenna, The Skew-Planar Wheel Antenna. David has a gread article on this http://www.flitetest.com/articles/The_Skew_Planar_Wheel_Antenna
TX antenna, The Cloverleaf antenna. David has annother great guide on this.http://www.flitetest.com/articles/Cloverleaf_Antenna
DIY FPV goggles, made with a 3.5" LCD, safety goggles, and a magnifier for eye relief.
Some More Pictures
FSMultirotors on September 20, 2013
Thanks for your comment. I'll make an instructional article next.
rezq911 on September 20, 2013
Nice job. A build log or link to instructions for the DIY goggles would be greatly appreciated.
rcflyer729 on November 14, 2013
nice job
