3D Printed Micro H-Quad
by ukarmy04 | February 25, 2013 | (9) Posted in Projects
This is my latest quadcopter build.  I wanted to make a simple design that was easy to work with and very durable.  After seeing all the recent H-quad builds, I wanted to make something similar but improve on some of the weak points in the conventional H-quad design.  I have also written a full build log as well as a comprehensive parts list for this quadcopter on my website: RC Tutor
I worked on designing a frame in Autodesk Inventor and this was what I eventually ended up with:
It looks close to a normal H-quad except for the fact that the arms are angled outwards about 25 degrees and the joints are all reinforced with extra material.  I chose this design because in my previous experience with H-quads, the main point where the frame would break would be at the arm joints.  By angling the arms, any sort of tumbling crash that might happen will transmit load more axially into the arms rather than perpendicularly.
I also took the opportunity to run a stress test in Autodesk Inventor by applying a load of 10 lbs to each of the arms. The results of the stress test looked like this:
As you can see, the main concetration of principle stress occurs at the joints where I have added more supporting material.  This is a good sign as it shows that the frame will be transfering crash loads to all the right places.
I had the frame printed for me by a friend using an AO-100 3D printer and it was made using ABS plastic.  All the parts I ordered came from HobbyKing with the exception of a few accessories.  Once I had the frame and all the parts, everything came together really easily.
Motor mounts screwed into place:
ESC's secured with zip ties:
KK2 controller board screwed into place:
Micro FrSky receiver connected to the KK2 board:
The final product:
If you have any questions or comments feel free to send me a message or leave a comment.  Hope you enjoyed!
TheRedBaron on February 25, 2013
thats super slick and excellent cable management. I agree I would love to see a video.
ukarmy04 on February 27, 2013
Video added!
TheRedBaron on March 15, 2013
I just saw this. I must say I'm really impressed with it. I love the design the way you kept it clean and simple. I would be curious to see what modifications to the design would make it capable for filming w/o compromising the size, because its perfect for indoor close quarters. Nice Job
ukarmy04 on March 15, 2013
Thanks man. I'm working on a redesign right now that will lower the weight of the frame while also making it suitable for FPV. Hopefully I can have it up and running soon - just waiting on a few parts to ship out from China.
TheRedBaron on March 16, 2013
I look forward to seeing it, it will be interesting to see, how vibrations will effect it.
ukarmy04 on February 25, 2013
Thanks! Working on a video now.
Sonicg on February 25, 2013
Nice design!
How does the ABS frame behave in relation with vibration?
Thanks! It's a little hard to tell how much vibration is being absorbed by this frame, partly because it's so small and partly because I don't have anything like a camera to test for jello and things like that. As far as what I can tell by just holding, I really don't feel any sort of bad vibrations going through the frame. The controller board is hard mounted straight to the frame and it doesn't seem to have any issues with vibration noise hitting the sensors.
Adib Vahedi on February 25, 2013
Wow it looks great it looks beautiful you did a great job building it!
Keep up the great work!!!!!!!!!!! ;)
ukarmy04 on February 26, 2013
Thanks, Adib!
philip monday on February 25, 2013
how does she fly?
It's great so far. I'm still getting the self level settings tuned it, but it turns on a dime and hovers at right abut 50% throttle. Definitely a lot of fun to fly especially because it's not as intimidating as the larger quads.
zev on February 25, 2013
could we see a video? pretty please?
Video added!
Rc Mania Cyprus on March 2, 2013
What propellers are you using?Can you provide a link for them or a similar product?
ukarmy04 on March 2, 2013
I'm using the 5030 black and red propellors from HobbyKing. There's a full parts list on my website:
http://www.rctutor.org/3d-printed-micro-h-quadcopter.html
Thanks.Great project.I'll subscribe to you in youtube!
awesome awesome awesome! that is some super nice and tight wiring you have there.
how heavy is the abs? would you recommend it as a build material?
Thanks! It's nice to have someone appreciate the wiring for once - I stripped and rewired the entire thing 3 times before I was happy with it. The entire quad weighs 210 grams and that's about 25g more than a comparable basswood frame of similar size. However, I think that's because it was printed with a higher than normal density. If the density were lowered, it would probably come very close to a similar basswood frame. Would definitely recommend it!
Auxiliarypower on February 25, 2013
? on your next version are you going to make the motor mount area bigger?
Possibly. I didn't want to add extra weight to this particular frame design if I didn't need to, but I might revise that in the next version so that others can use different style motors.
cloud9photos on February 25, 2013
That thing looks like a work of art!!! Very well done.
Thank you very much!
gtrguy on March 1, 2013
Nicely done, save a gram or two and cut those motor mounts...
Nathan_116 on March 3, 2014
About how much did this cost you to build excluding frame and receiver?
Thanks, Nathan
