Small indoors FPV Quad Project
by Hasi | February 26, 2015 | (7) Posted in Projects
I wrote a blog on RCGroups about my micro sized FPV Quad project, which became very popular, so I thought I'll post it on flitetest. I wanted to have a small FPV Quadcopter, so I can also fly indoors. My goals were small size, some crash resistance, reasonable flight times and performance, good video quality, good flight characteristics, reasonable range, and I wanted to use my existing transmitter which is a Taranis with a FlySky (same protocol as the Turnigy 9X) module in the back.
Small size & crash resistance: There are some frames out there, but I chose one of the 100 sized platform frames from picnicquads.com. It is made out of a sandwich composite material, so it is tough, yet very lightweight. You can also choose from different motor sizes, because the motor mounts are separate.
Flight times & performance: To accomplish these I did some research on RCGroups about the best motor/prop combo. Next I calculated the MTOM to be about 50g with a bigger (750mAh 1S LiPo) battery, which meant I need to have 100g+ thrust. RCG member woodsturning did a lot of micro quad equipment testing and for my needs the Chaoli CL-0720 motors with the Hubsan propellers seemed to be the best.
Video quality: After watching some DVR videos of small cameras I decided to use a 520TVL MC900 with a wide angle lens from FPVHobby. It has a really nice image and also works in low light conditions. I have a Fatshark Base with a built in receiver, which is fixed on 5705Mhz, so the VTX also had to have this frequency. The TX5810-100 also from FPVHobby has this Frequency, so I bought it despite the unreasonably high price. It also turned out, that the channel memory doesn't really work. It only works if I disconnect the battery for a few seconds. Otherwise I always have to cycle through all 8 channels to see a picture in my goggles. I also had to use a Pololu 5V step up voltage regulator to get rid of the noise from the motors.
Flight characteristics & range: This was the complicated part. Because of the size and weight limitations a separate RX and FC was out of the question. Since there is no available Frsky or FlySky micro FC on the market I had to build my own. RCG member midelic already had an ongoing project to build a Multiwii board with integrated brushed controllers and FlySky RX. He wouldn't build me one, so I built my own. Since 1 piece would have cost me a fortune I ordered parts for 18 pieces and decided to sell the rest later. I built my own and did some testing. There were some bugs in the code first, but midelic fixed them for me and now it works flawlessly.
Conclusion: All together the quad cost me $175. Despite the problematic and expensive VideoTX it all came out working very nicely. Range is very good. Indoors I flew about 50m with several walls between me and the quad while maintaining good control and adequate image quality. Currently I am using 500mAh 1S LiPos, because I already had them. I get flight times of about 8 minutes, so there is really no need for the bigger battery. T/O weight including the battery is 45g, which is lower, than calculated. The performance is very nice and the control is very precise. I can fly through holes that are twice as bis as the quad.
Ad: If you ever have the same problem like me with the small FC, contact me and I will sell you one of the boards. I build and test each one myself. The dimensions are 43x25mm (including PCB antenna) and it weighs only 2.7g. I sell them for $30 including worldwide shipping. I of course have midelic's permission.
Rust15 on March 3, 2015
Cool article and nice micro quad!! Would your board be compatible with a Spektrum compatible transmitter? Sorry if that's a dumb question, but I'm not very familiar with the different radio brand compatibilities.
Hasi on March 4, 2015
No. It's only compatible with the FlySky system (radios like FlySky/iMax/Turnigy 9x/Eurgle 9CH, Turnigy i10, HobbyKing T6A).
However there is a board similar to this, but for Spektrum on HobbyKing: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=42255&aff=395981
spastickitten on March 5, 2015
I would love to see more and might buy a board can you give me a parts list?
Hasi on March 6, 2015
There are links to the parts I used in the article if you look closer.
FTprime on March 6, 2015
I would love to see a video
spastickitten on March 6, 2015
So I am thinking of making a mini tricopter so any ideas or help?
Hasi on March 7, 2015
Not this small, but I already have built a small tricopter: http://www.rcgroups.com/forums/showpost.php?p=29600988&postcount=6948
spastickitten on March 7, 2015
I have seen some stuff that will be perfect like lemon rx's ppm receiver and the naze mini and the cc3d racing edition and the flip32 racing edition and these https://www.sparkfun.com/products/9457
I also would like to see where you got the esc components to make my own. I can't find any escs for the small motors and i would love to see how you did it!
The ESCs are integrated into the board.
also if you make a board with an output for the servo part I might get it!
Hasi on March 12, 2015
I think we can arrange that. PM me on RCGroups, or on the flitetest forum.
http://www.rcgroups.com/forums/showthread.php?t=2367903
IronKane on March 12, 2015
I'd like to buy one of those boards. How do I get one?
Contact me on RCGroups: http://www.rcgroups.com/forums/showthread.php?t=2367903
Or on the flitetest forum.
fastfred529 on May 1, 2015
I want one.
