Scratch Built de Havilland Beaver (Free Plans!)
by Captain T | March 13, 2015 | (11) Posted in Projects
One day I was flying my HK Bush Master and a tree popped out of nowhere and destroyed the plane. The electronics were fine so I decided to make a new plane from the electronics. I decided to try and recreate the de Havilland Beaver. I chose the Beaver because it looked like a relatively simple design and I have always loved this type of STOL aircraft.
I started the build by studying some diagrams I found on the interwebs.
After I got some of the general design aspects from the diagrams, I started cutting out the wing. The wing is 60 inches long and has a 22cm chord. It has 11 inch ailerons and has 15 inch flaps. I wanted big flaps so it could slow way down and take off in a few feet. I am using four 9 gram servos on the wing (2 for ailerons and 2 for flaps. One reversed)
Then I took some pictures off the internet of the Flyzone Beaver to try to copy the color scheme the best I could. I used colored packing tape to do all the colored parts.
I also used a very dense plastic material for the wing spar so I don't fold the wings. I have lots of experience with folding wings on big planes, so I didn't want to take a chance on this one.
After I got the wing looking the way I wanted it to, I started on the fuselage. The fuselage was pretty easy other than the windows. I don't have any artistic skills whatsoever, so I asked my Mom to do the windows. I think they turned out quite good! I also had some old 5.5" tires from a 200% spitfire that I decided to use on this. They look so cool!
The landing gear is from the Bush Master too. I cut a hole in the bottom of the fuselage and glued the mount inside the plane rather than outside to give it a cleaner look. I also ran 2 carbon spars where the landing gear mounts to strengthen the foam
After my Mom sketched out the shape of the windows, I went over it with black packing tape.
Then it was time to mount the motor. The motor mount I had was kinda strange so I had to use BBQ skewers to hold it in place, I also cut out a small sheet of 1/8'' plywood to help hold it in place.
The battery is mounted just behind the CG on a balsa battery tray from the Bush Master.
I decided to mount the wing with simple rubber bands because it was easy and it worked. I used some of that dense plastic spar material to hook the bands onto.
After I finished the fuselage and wing, I started on the tail section. I used the 25 gram servos that came with the Bush Master, but I think 9 gram servos would have been fine. I think I kinda messed up the vertical stab shape, but it works so... ya. I also added the little winglet type things to the horizontal stab to match the Flyzone Beaver.
 The servos are located under the wing.
Here are some specs
Motor: 3648 700kv Brushless Outrunner
ESC40A
Servos: 9g x 425g x 2
Wingspan: 60''
Length 40''
Battery: 2200 4s 40-80c
Prop: 12x8
Weight: 56 oz
Wing Loading: 12.8 oz per square foot
This is a video of the second flight. I was alone for the first so I couldn't film it.
Thanks for reading!
Miracle Air on March 13, 2015
Yeah, the trees where I live are particularly aggressive. I've talked to the county about it but they're overworked anyway. Maybe we should allow a controlled hunt.
That's a sweet flying plane, and I love the tape job.
Desert Wings on March 13, 2015
You have been busy this winter. Good job on the scratch builds.
sailorJohn on March 13, 2015
Nice video and article, Jeffco reromodelers at Chattfield dam has a great paved flying site open to the public with AMA . or Arvada rc which is closer to you. Saddly you have missed the big Jeffco auction but watch for Warbirds over Denver. Your lucky to have Thomson's hobby near you.
Captain T on March 13, 2015
I fly at Arvada on occasion. I missed the auction too. I really wanted to go but I couldn't:( Where is Thomsons Hobby?
PropSpinner on March 14, 2015
Impressive model. It's cool that your Mom helped in FliteTest fashion.
sailorJohn on March 14, 2015
Sheridan and Colfax in the rear ,used to be the best source for balsa, kits, and decals, stuff old time hobby shops used to have
dharkless on March 16, 2015
You are not really 14, are you. 28? 47?
Captain T on March 16, 2015
No, I am 14, but I believe I am 45 on Facebook because,,,, Auctually,I don't know.
I was just trying to say that you are quite accomplished for your age. Keep up the good work.
! didn't make a plane bigger than me till I was 63!
Thanks, I Love your work! You made some of my favorite articles!
Phantom_flyer on April 12, 2015
I love this design and am making modifications to mine I am building. with mine though it only has an elevator and a rudder
Jake3dpilot on July 25, 2016
Awusome build up Toby
Captain T on July 25, 2016
Thanks!
I might make one with bigger control surfaces
That will be so cool!
