FT Mighty Mini F-22 Raptor Build
by FliteTest | March 28, 2016 | (9) Posted in How To
The FT Mighty Mini F-22 has all of the excitement of the full-scale F-22 packed into a miniature version!
The Mini F-22 speed build kit is laser cut into our new Water-Resistant Foam Board! Learn more about the Water-Resistant foam kit HERE!
This plane is a little more versatile indoors or in tight surroundings than its original counterpart. It's a blast to fly and just as agile as the F-22!
The Mini F-22 can be powered by a 2300 kv 2204 motor or a 2280 kv 1806 motor.
GET THE SPEED BUILD KIT HERE!
FT MIGHTY MINI F-22 SPECS
  • Weight without battery: 4.8 oz (134 g)
  • Center of Gravity: 14 inches (355 mm) from the nose
  • Control Surface Throws: 25° deflection (elevons) Expo 30%
  • Wingspan: 20 inches (508 mm)
  • Recommended motor: 2300 kv 2204 or 2280 kv 1806 motor
  • Recommended prop: 6 x 4.5 prop
  • Recommended ESC: 12 amp minimum
  • Recommended battery: 800 mAH 3s minimum
  • Recommended servos: 5 gram servos
FT MIGHTY MINI F-22 PLANS
STORE LINKS
New to the R/C hobby?
Here’s some resources to help get you up to speed!
Beginner Series: WATCH HERE!
Electronics Setup: WATCH HERE!
First Flight Quick Tips: WATCH HERE!
Got glue?? Get some here!
s7726 on April 16, 2016
Building this from the plans. I noticed that the front two slots cut into the wing to receive the tabs from the fuselage are 1/8" smaller than all the other slots and the tabs they are meant to receive. Hope there isn't something else I'm missing.
Eheff on April 20, 2016
"Hot glue is hot!"
-Josh Bixler, 2016
Travos on April 21, 2016
This article is hard to find, unless I'm totally blind it doesn't show up with the "scratch builds" link that is on the home page that I always use to decide my next Ft build, and even typing in "mini ft22" in the search doesn't find it.
ancientace on March 29, 2016
Dear Flitetest,
I'm a new member of the hobby and your two new planes look good. whilst your on the subject of this kind of plane, can you please consider creating another EDF? From Australia, The Ancient Ace.
The-One-Who-Never-Crashes on March 30, 2016
+1!
manipaj on April 28, 2019
You can get it from Kmart for 5 dollars and from office works. Office works has different sizes as well
TheBadEgg on July 30, 2016
I've been building flight test plans for a while. And well I have a need for speed, so I build the mini F-22 raptor. I didn't intend for it to go to fast but, it does, we were guessing around 110-120 mph. Also this plans in durably at full speed it smashed into a corn field and with in 20min of flattening it was ready to fly again. GREAT PLAN!
dershan on May 26, 2017
hi guys,
i have designed a wing for your mini f-22 raptor. That is its a foam fighter similar to your mini f-22 raptor ,same body, same things except the wing . I had a design for a fighter and i designed it , to make it real and easy i just swapped my wing design to your raptor frame or body.Please try out this design.
https://drive.google.com/open?id=0B_WuCi9yUh_3R2Zlb21GS2JqRkU
yours faithfully
Devadershan
newbiehobbyguy on August 5, 2017
will this work with 9 gram servos
KryptoSteel24 on January 22, 2018
Anyone run this with 4s ?
eslimm00 on April 10, 2018
will this work with 9 gram servos Reply
TooJung2Die on August 26, 2020
Yes.
I don't know why this airplane hasn't had more attention. It's a whole lot of fun for a small investment in time and material. As Josh says it may not be the best jet for slow speed high alpha but it flies fast and tracks like an arrow. I like it!
Jon
Vaibhav303 on September 30, 2021
Need help!! I have 3s 2200mah battery with weight of 180g can I use it in this flight plan?
