Durafly Spitfire by FliteTest
Rating: 4.65      17 ratings
Posted: November 22, 2010  |  5,570 views
INFLUENCE 92%
The Supermarine Spitfire, made by Durafly (a Hobby King brand), is a beautiful warbird that is just plain fun to watch as it flies by! Josh Bixler talks about the retractable landing gear, durable construction and scale appearance while Josh Scott gets a little stick time. Don't miss this episode of Flite Test or all of your RC buddies will make fun of you. Please note: You need a 6CH RX or a servo reverser to get the landing gear to work properly.
International Warehouse: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=10778&aff=247441
US Warehouse: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=14513&aff=247441
FROM HOBBY KING'S WEBSITE:
The Durafly SuperMarine Spitfire 1.4M is a large scale, high quality EPO model, and includes steerable tail wheel, Shock Absorbing Retractable Landing Gear. Due in part to its large size, the SuperMarine Spitfire has excellent flight characteristics making it a great plane for beginners & intermediate pilots. Included is 6 servos, 11x7E propeller, and a large high quality 35 series outrunner. The Durafly SuperMarine Spitfire will arrive 95% RTF, leaving only the tail pieces and wing to be screwed into place. Assembly time is around 15 minutes.
Just include your own RxESC and a battery to be ready to fly. Note: Tail servos have been upgraded to heavy duty 12g versions to prevent servo failure on hard landings due to the large tail control surfaces.
Spec. Length: 1190mm
WingSpan: 1420mm / 55.9in
Propeller: 11x7E
Flying Weight: 1650g
Motor: C3542 Brushless outrunner 1100kv
ESC: 40A (Not included)
Battery: 11.1v 2200~2600mAh 3S1P (Not included)
Servos: 6 Total (9g x 4 ailerons/rudder/elevator) (20g x 2 retract 180deg)
Battery compartment size: 150 x 55 x 32mm
Required. 40A Brushless ESC 5ch Tx & Rx (aileron/elevator/rudder/throttle/gear) 11.1v 2200~2600mAh 3S1P Lipo
*Note: This model has a wingspan of 1.4m, it is noticeably larger than a normal foam plane. Due to the Spitfires elliptical wing it has a tendency to tipstall, however Durafly designers have created the model with 2 degrees of wing-tip washout to help prevent this phenomenon.
» Join the discussions on our forums
Comments
pyc789 July 15, 2012
i what to be the two joshes because so i can fly alot
monoton July 11, 2012
How many Watts is that motor? It's nice looking airplane and an awsome review. as always! boy'o'boy!
radar5150 July 15, 2012
Great review! But I'm having trouble finding that model as well??? The only spitfire of that size is one made from balsa for glow engines. I hope it's not discontinued.
Benn Gunn August 18, 2012
great review as always boys
planeaddict August 30, 2012
Wow, where can we get this plane?
kiwideno July 8, 2012
They don't have them listed any more in the international warehouse.
Log In to leave comments
