FT old fogey Review
by Neskair | November 19, 2015 | (7) Posted in Reviews
Hello, this is going to be a review on the FT Old Fogey.  I hope to share my experience building and flying this great plane, but I am rather new to this so it may not be very good.  I will first show the build process, then my experience flying it, and last, a few notes on how the plane performed.
         I built the plane in about 3 hours. It was very easy to build, with the exception of the landing gear.  The landing gear was very hard to bend.  I think the best way to bend it is with a vice and pliers.  Or maybe I'm just a weakling.  Josh bent the wire pretty easily in the video.  I wonder if the kit wire is the same as the wire in the video?
I think the wire could be straighter, but I doubt if I could get it there.  (I dont have a vice and I can't seem to get it it better.)
Here's the wing all done.  I put packing tape on the wing breaks to make it stronger, but I dont think you actually need it.  The wing is pretty strong by itself.
The fuselage was a little trickier to make because of the control surfaces, but stil easy.  I have the servo tray in, and control horns istalled.
I used some yellow tubing I had laying around for the wire guides.
Heres my power setup.  I'm using a ar6100 rx with a DX5e.  At the time I bought the power pack the picture showed a xt60 connector but the description said it had a jst plug, so I ordered it and decided to buy a battery after it arrived.  When it arrived it had a xt60 so I bought a adapter to use it with my old 1300mah 3S.  I wanted to use a 1000mah lipo, but I didn't want to wait forever for a battery.
 The plane is finished now, I minwaxed the outside of the fuse, and top and bottom of the horizontal stabilizer.  I just need to fly it now.
THIS IS THE END OF THE BUILD PROCESS.
I took the plane to a park nearby for the maiden flight.  On my first hand launch, It went about 4 feet before hitting the ground.  I removed the landing gear to save wheight, which i probably should've done in the first place since I was hand-launching.  On my second throw, the Fogey flew great!  I had not flown a real rc plane for about a year, but practiced a bit on an iPAD simulator.  I flew it around the field a few times before coming in for a rough, belly-flop sort of landing.  I could feel tail-heavyness in it, so I moved the battery forward a few times before getting it well balanced.  I have flown it at home about 12 times now.
  This plane flies great in calm weather.  Wind pushes the plane around a lot so I wouldn't recommend flying on windy days.  The motor is way overpowered for this plane. You can get almost vertical at full throttle!  I rather like this though because whenever I get too close to a tree or whatever, it powers right out of there at almost a 45 degree angle!  I fly pretty nose heavy, and the plane keeps its speed up very well when gliding.  Below I will list a few problems I had.
  • Every time I landed, the battery would fly out becasue the velcro couldn't hold it in place too well.   I made a velcro strap to go around the battery and hold it in.
  • The rear bbq skewer pulled out of the foam when I crashed once.  I glued it in but it happened again.  I cut up a hotel card and glued it over the skewer to keep it from tearing.
  • My reciever lost connection on one flight and I suspected it was because the rx was too close to the ESC. (Is this possible?)  So I made a velcro strap to hold the receiver up high.
So that is all for my review.  This is a great plane that is easy for beginners to build and fly.  I recommend flying on a simulator before flying this plane, but that probably goes for all planes.  Its a good trainer, and very forgiving when it crashes.  I hope this review can help someone who wants to kow more about the FT Old Fogey.  Please leave suggestions, in the comments.  Thank you for reading my post.
The-One-Who-Never-Crashes on December 26, 2015
Nice review and great tips! Thank you!
Neskair on December 27, 2015
Thank you! I'm glad you liked it.
ABCrc on December 27, 2015
nice clean build keep up the good work!
Neskair on December 28, 2015
thanks!
I-did-it? on January 19, 2016
I think its REALLY cool!
FT old fogey Review
