Rad Jet by FliteTest
Rating: 4.84      31 ratings
Posted: May 7, 2012  |  3,939 views
INFLUENCE 92%
In this episode of Flite Test Josh and Josh talk about the Rad Jet! Not only are they reviewing the 800mm, but also the 420mm! Watch as they put them through the test.
Rad Jet 800:
Wingspan or Rotor Size (in mm) - 800mm
Flying Environment - Outdoor
Experience Level - Intermediate
Power Type - Battery
Number of Channels - 4
Frequency - 2.4 Ghz
Aircraft Type - Jet
Prop Diameter (in inches) -
Prop Pitch (in inches)
Battery Capacity (in mAh) - 1300
Battery Cells - 3s
Build Type - PNF
Motor/Engine Size - 1850kv
Airframe Material - EPO
Rad Jet 420:
Wingspan or Rotor Size (in mm) - 420mm
Frequency - 2.4Ghz
Aircraft Type - Jet
Battery Capacity (in mAh) - 180
Battery Cells - 2s
Build Type - PNF
Motor/Engine Size - 3000kv
Airframe Material - EPS
» Join the discussions on our forums
Comments
kevski46 August 27, 2012
I recently bought a radjet 800 from HK. It took over a month to arrive as I live in the u.k so i wasn't too bothered about that. I bought the the pnp version which was a BIG mistake! Loads of the screws were missing, the stickers had been put over the ailerons so they had to be sliced and there were dents in the wing and nose of the plane had been squashed quite badly. They also glued the fuselage on instead of using magnets so I cant change the ESC if I wish to upgrade. All in all,,very sloppy workmanship, there was blobs of glue everywhere. I would advise everyone to buy the kit version.
SeanJuan73 May 7, 2012
I was considering a F-27Q Stryker but the rad jet is a 3rd of the cost!! Plus the F-27Q Stryker 180 sucks, one crash and it was $150 jigsaw puzzle... at $50 it wouldn't hurt the wallet so much.
Pozzix May 9, 2012
Hi, just a few questions..
What about the CG of this plane?
How is better to set this?
I found that this one, is a bit wrong respect manual.
Can you advise about correct location and any trick.
Thk guys.
TaPeMaStEr153 July 21, 2012
If HK had stock of this in USA I would buy one right away! Great review. Would be cool to do a same time comparison of the larger f-27Q stryker and the 800 mm Radjet.
Flightdeck May 8, 2012
Hello Fellas,
Glad you guys reviewed this one. I just purchased Flyjet X 83 with a 64mm EDf system all from Hobbyking. Still putting it together but looking forward to the first flight. This review gives me some idea what to expect. (Flightdeck)
Trondareo May 8, 2012
It looks likt the little one may fit on top of the tail fins of the big one, space shuttle style. It would be really cool to se an in flight release!
fmata5 August 15, 2012
Could not find a lot of info on props for the RADJET 800 would you know what my options are?
Thanks..
gsantos_92 May 8, 2012
Next video: "Radjet power upgrade" xD
lozzer2012 May 8, 2012
next video - shooting the rads (or least attemping to) with a couple of paintball guns ;)
Log In to leave comments
