KK2 Battery Alarm Wiring and Setup
by rctestbench | December 27, 2012 | (9) Posted in Tips
this video shows how to attach wires to the KK2 board to monitor voltage, then shows how to set up voltage alarms on the KK2 board
MidwestRob on December 31, 2012
Great job with all your how-to videos. Very clear and easy to follow along. Thanks for sharing.
Splat01 on July 10, 2013
Thanks for this video. I've looked at several others trying to become familiar with setting up an alarm, and yours is by far the easiest to follow. Thanks again!
gizmatron on January 6, 2014
Is there an update to this cause I have just bought the newer KK2.1 board and there is no longer the hole in the board for the red wire?
Joking on January 26, 2014
Hi Giz. I had the same problem with KK2.1 board monitoring the voltage. When powered up it would not show any voltage on the home screen. I did some research and it turns out to be quite easy to do. If you look on the board on the left hand edge just below the fixing hole are the voltage monitoring pins. I took a pin from an old servo lead, the red one and pushed it onto the left positive pin, nearest the edge (see Hobby King data sheet) then solder onto positive wire from battery where it meets the copter frame. Good flying.
