FPV Sunset by ycopter
Rating: 4.17      12 ratings
Posted: June 22, 2012  |  729 views
INFLUENCE 76%
Tricopter flight at sunset in between the ancient oak trees on the Calke Estate plus maiden FPV flight of my large quadcopter.
Thanks to Steve aka ukbozzy for his ground camera work.
http://www.nationaltrust.org.uk/calke-abbey/
Music: Where Next by Vivo http://soundcloud.com/vevov/where-next
Tricopter
2200mah Turnigy 25C 11.1v (6 minute flight time)
Motors - NTM Prop Drive 28-36 750KV / 265W
18 AMP RC Timer speed controllers
HK KK V1 board V1.6 firmware
10x4.7 SF props (Genuine APC)
Turnigy 9X radio with ER9X software and FrSky module
FrSky V8FR (HV) receiver
Quadcopter
850mm motor to motor span
5000mah Turnigy 25C 14.8v (10 minute flight time)
30 AMP RC Timer speed controllers
HK KK V2 board V4.6 X mode firmware
Comments
ukbozzy June 23, 2012
Another great video! Im glad i could help, and thanks again for giving me my first taste of FPV :-)
ycopter June 23, 2012
You are welcome, thanks for your assistance.
SuperCub92 June 25, 2012
Another Great video..
can u list ur fpv gear please :)
ycopter June 27, 2012
Hello SuperCub92. FPV Camera 600TVL SONY SUPER HAD CCD D-WDR. Fatshark Base RCV922. TX BEVRC 400mw 1280Mhz with inverted vee antenna. RX 1 - 8dbi patch, RX 2 - Inverted vee. Range video simple diversity.
Jake Wells June 24, 2012
What are your settings on your GoPro? Thanks in advance.
ycopter June 24, 2012
GoPro HD2 760p 60fps.
Huwy11 June 28, 2012
You should make some UAV Drone type things, Just with plastic bodies and frames etc. and neater wiring ect.
Log In to leave comments
