Clover Leaf Antenna Build for 5.8Ghz FPV - IBCrazy
by bmsweb | May 8, 2012 | (24) Posted in Projects
This is how I go about building 5.8Ghz Antennas. They seem to work great and significantly increase range and quality of video feed. In any case I hope you find this video helpful. Its worth noting that this is the IBCrazy design antenna and not mine and the technique I use to build it is for the most part as per David's method on his web site http://www.rcexplorer.se/
JoeTapia on May 16, 2012
great tutorial! it really cleared up the part of the build i was a bit fuzzy on. thanks!
bmsweb on May 17, 2012
Thanks for the feedback, I'm happy it helps. David has his article on this site too now, so you plug in your figures :)
Manuel on September 29, 2012
This is extremely helpful. Thanks so much for this video.
bmsweb on November 5, 2012
You're very welcome :)
Funky Diver on May 12, 2012
I never quite got the curves right with the SPW / Clover... but I know guys that swear by these antennae.
I went down the virivent / windmill route instead :)
schraut5 on May 9, 2012
Nice build! What size/type of wire are you using here?
bmsweb on May 10, 2012
This once is a little too thick. I ended up using 1mm thick wire, I'm pretty sure 0.8mm would have been better . . The up side is it work and works really well
Jet760 on May 16, 2012
Really a great build, made things easy to do. Thanks
Thanks for the feedback :)
Don't forget to check out Davids article on this site :)
joneill4 on March 16, 2015
First, great tutorial. This looks very DIY doable. Hobby King sells these for $6. Some friends of the site sell them for $70. With such a short parts list, where could the difference possibly be?
jonathancod on October 7, 2015
Branding.
